I’m using QoS PCQ and it’s working well. Actually what is my problem. When im testing the capacity from B-Test i’m getting full capacity, not the capacity when i been set up, also when im testing on speedtest.net it shows up the values same as i’ve written on QoS.
Well i like to get same resolt on btest as speedtest.
You see the problem?
You are shaping “forwarded” traffic, then you need to test “forwarded” traffic. Not from the router itself, but from a client behind it.
Also not good. You need to test it from a client at one side of the router to a server on the other side (e.g. on internet).
When you want your queues to work on input and/or output, you need to mark the input and/or output traffic like you marked the forward traffic.
