Just i want to know which is the max value that i can play with Bucket size.
By default is 0.100.
I think that i’ve see that max value is 10, but i’m not sure can i have your help.
“bucket size (0..10, Default:0.1) - queue option was added in RouterOS v6.35, before that it was hard-coded to a value of “0.1”.”
https://wiki.mikrotik.com/wiki/Manual:HTB-Token_Bucket_Algorithm
you are number one
I think you meant CZFAN is number ZERO! at least in Ebola terms. ![]()
