QoS by device
I’m currently using simple queues for QoS on a wireless configuration with 5 clients and 1 AP.
Is there way to give one of the wireless clients lower priority? I am needing this because 4 of the clients connect to our work buildings, but the 5th connects a home, and I would like to give the home connection ultra-low-priority.
These are all using RouterOS 3.2
hi…
you should explain you problem
but
you can set QOS with ip and device for each user.
if you try in que mode you can find the device in it
good luck
