Admittedly I am still super new at dealing with these QOS rules, but Im eager to trust them and see that they can really protect my networks from having failures on the most critical networks. Right now this config is on a CCR2116 and has two sets of rules for two isps that will be triggers on and off with netwatch if there is a failure on ISP1. What im curious about is the Limit-At 310 on the total parent que. So I leave this blank or equal it out to the max limit.
also if there are other things that look off please let me know
Thank you everyone!
/queue simple
add comment=MediaQOS disabled=yes max-limit=200M/200M name=Media target=10.170.0.0/22
add comment=ISP1_QUE_TOTAL limit-at=310M/310M max-limit=920M/920M name=total target=192.168.0.0/16,10.0.0.0/8
add comment=ISP2_QUE_TOTAL disabled=yes max-limit=40M/500M name=total-ISP2 target=192.168.0.0/16,10.0.0.0/8
/queue type
add kind=pcq name=pcq-up-2M pcq-classifier=src-address pcq-rate=2M pcq-total-limit=5000KiB
add kind=pcq name=pcq-dl-20M pcq-classifier=dst-address pcq-rate=20M pcq-total-limit=5000KiB
add kind=fq-codel name=fq-codel-default
/queue simple
add comment=ISP1_QUE_BARS_TICKET_MERCH limit-at=300M/300M max-limit=750M/750M name=bars-ticketing-merch parent=total priority=5/5 queue=fq-codel-default/fq-codel-default target=10.150.0.0/20,10.140.0.0/22,10.180.0.0/22 total-queue=fq-codel-default
add comment=ISP1_QUE_STAFF_CAMERAS limit-at=300M/300M max-limit=750M/750M name=staff-cams parent=total priority=6/6 queue=fq-codel-default/fq-codel-default target=10.130.0.0/22 total-queue=fq-codel-default
add comment=ISP1_QUE_MANAGEMENT limit-at=300M/300M max-limit=800M/900M name=management-others parent=total priority=7/7 queue=fq-codel-default/fq-codel-default target=192.168.200.0/24,10.10.10.0/23,10.4.1.0/24,10.7.9.0/24 total-queue=fq-codel-default
add comment=ISP1_QUE_GUEST limit-at=50M/50M max-limit=200M/490M name=guests parent=total queue=pcq-up-2M/pcq-dl-20M target=10.169.0.0/16 total-queue=fq-codel-default
add comment=ISP2_QUE_ALOHA_CLOVER disabled=yes limit-at=10M/100M max-limit=38M/490M name=aloha-clover-ISP2 parent=total-ISP2 priority=5/5 queue=fq-codel-default/fq-codel-default target=10.150.0.0/20,192.168.192.0/24 total-queue=fq-codel-default
add comment=ISP2_QUE_STAFF_CAMERAS disabled=yes limit-at=15M/100M max-limit=38M/490M name=staff-cams-ISP2 parent=total-ISP2 priority=6/6 queue=fq-codel-default/fq-codel-default target=10.130.0.0/20 total-queue=fq-codel-default
add comment=ISP2_QUE_MANAGEMENT disabled=yes limit-at=5M/50M max-limit=38M/490M name=management-others-ISP2 parent=total-ISP2 priority=7/7 queue=fq-codel-default/fq-codel-default target=192.168.200.0/24,10.10.10.0/23,192.168.8.0/24,10.4.1.0/24,10.7.9.0/24 total-queue=fq-codel-default
add comment=ISP2_QUE_GUEST disabled=yes limit-at=5M/100M max-limit=38M/490M name=guests-ISP2 parent=total-ISP2 queue=pcq-up-2M/pcq-dl-20M target=10.169.0.0/16 total-queue=fq-codel-default
