I am trying to configure QoS for a WAN connected office which needs to send and receive an UDP audio stream (a transport stream, few channels about 400Kb/s each direction). The application using those streams is very sensitive for delays, jitter, and packet loss. The location has also few dozens of local users, so they are generating some significant traffic. The stream quality is not good enough.
I hope you can give me some advice what is wrong with my configuration and how to fix it
I’ve tired few ways but did not get any significant improvement. My last idea was to use DSCP and PCP values which are used by the rest of the network and the WAN Provider. My configuration should:
- mark traffic with required DSCP valuses
- remark DSCP to priority
- add packet marks according to set priority
The WAN interface is using tagged frames, so the provider can apply priority to the traffic and the rest of our network trusts DSCP headers.
The diagram below shows simplified setup, the BO1 location is using an advanced L3 switch and performs way better (however it is smaller with fewer users)
My configiration:
add name=bridge1-lan
add bridge=bridge1-lan interface=ether3-lan
/interface vlan
add interface=bridge1-lan name=vlan170 vlan-id=170
add interface=bridge1-lan name=vlan171 vlan-id=171
add interface=bridge1-lan name=vlan172 vlan-id=172
add interface=ether1-wan1 name=vlan3012 vlan-id=3012
/queue type
add kind=cake name=cakeUP
add kind=cake name=cakeDOWN
/queue interface
set ether1-wan1 queue=multi-queue-ethernet-default
set ether3-lan queue=multi-queue-ethernet-default
/queue tree
add comment="Uplink QoS" max-limit=100M name=QoS_UP parent=vlan3012 queue=ckeUP
add comment="Downlink QoS" max-limit=100M name=QoS_DOWN parent=bridge1-lan queue=cakDOWN
add comment="Queue Priority 1" name="UP IP Precedence 7. Network Control (Top Priority)" packet-mark=up_ip_precedence_7 parent=QoS_UP priority=1 queue=ckeUP
add comment="Queue Priority 2" name="UP IP Precedence 6. Internetwork Control (High Priority) " packet-mark=up_ip_precedence_6 parent=QoS_UP priority=2 queue=ckeUP
add comment="Queue Priority 3" limit-at=5M max-limit=5M name="UP IP Precedence 5. Voice (Medium-High Priority) " packet-mark=up_ip_precedence_5 parent=QoS_UP priority=3 queue=ckeUP
add comment="Queue Priority 4" name="UP IP Precedence 4. Interactive Video (Medium Priority)" packet-mark=up_ip_precedence_4 parent=QoS_UP priority=4 queue=ckeUP
add comment="Queue Priority 5" limit-at=2M max-limit=2M name="UP IP Precedence 3. Critical Data or Call Signaling (Medium-Low Priority)" packet-mark=up_ip_precedence_3 parent=QoS_UP priority=5 queue=ckeUP
add comment="Queue Priority 6" limit-at=85M max-limit=85M name="UP IP Precedence 0. Best Effort (Low Priority)" packet-mark=no-mark parent=QoS_UP priority=6 queue=ckeUP
add comment="Queue Priority 7" name="UP IP Precedence 2. Background (Very Low Priority)" packet-mark=up_ip_precedence_2 parent=QoS_UP priority=7 queue=ckeUP
add comment="Queue Priority 8" name="UP IP Precedence 1. Scavenger (Bottom Priority) " packet-mark=up_ip_precedence_1 parent=QoS_UP queue=ckeUP
add comment="Queue Priority 1" name="DN IP Precedence 7. Network Control (Top Priority)" packet-mark=dn_ip_precedence_7 parent=QoS_DOWN priority=1 queue=cakDOWN
add comment="Queue Priority 2" name="DN IP Precedence 6. Internetwork Control (High Priority)" packet-mark=dn_ip_precedence_6 parent=QoS_DOWN priority=2 queue=cakDOWN
add comment="Queue Priority 3" limit-at=2M max-limit=2M name="DN IP Precedence 5. Voice (Medium-High Priority)" packet-mark=dn_ip_precedence_5 parent=QoS_DOWN priority=3 queue=cakDOWN
add comment="Queue Priority 4" name="DN IP Precedence 4. Interactive Video (Medium Priority)" packet-mark=dn_ip_precedence_4 parent=QoS_DOWN priority=4 queue=cakDOWN
add comment="Queue Priority 5" limit-at=5M max-limit=5M name="DN IP Precedence 3. Critical Data or Call Signaling (Medium-Low Priority)" packet-mark=dn_ip_precedence_3 parent=QoS_DOWN priority=5 queue=cakDOWN
add comment="Queue Priority 7" name="DN IP Precedence 2. Background (Very Low Priority) " packet-mark=dn_ip_precedence_2 parent=QoS_DOWN priority=7 queue=cakDOWN
add comment="Queue Priority 8" name="DN IP Precedence 1. Scavenger (Bottom Priority)" packet-mark=dn_ip_precedence_1 parent=QoS_DOWN queue=cakeDOWN
add comment="Queue Priority 6" limit-at=85M max-limit=85M name="DN IP Precedence 0. Best Effort (Low Priority)" packet-mark=no-mark parent=QoS_DOWN priority=6 queue=cakeDOWN
# firewall mangle
/ip firewall mangle
# mark local traffic with DSCP
add action=set-priority chain=postrouting comment="Prioritize ACKs" new-priority=6 packet-size=0-123 protocol=tcp tcp-flags=ack
add action=set-priority chain=postrouting comment="Respect DSCP tagging" new-priority=from-dscp-high-3-bits
add action=change-dscp chain=input comment="BGP Top Priority" new-dscp=46 protocol=tcp src-port=179
add action=change-dscp chain=output comment="BGP Top Priority" dst-port=179 new-dscp=46 protocol=tcp
add action=change-dscp chain=input comment="SSH Top Priority" dst-port=22 new-dscp=26 protocol=tcp
add action=change-dscp chain=output comment="SSH Top Priority" dst-port=22 new-dscp=26 protocol=tcp
add action=change-dscp chain=input comment="WinBox Top Priority" dst-port=8291 new-dscp=26 protocol=tcp
# remark outgoing traffic with DSCP
add action=change-dscp chain=postrouting comment="Mark users BE(0)" dst-address-list=qos-users-dst new-dscp=0 protocol=tcp
add action=change-dscp chain=postrouting comment="Mark LOW AF13(14)" new-dscp=14 protocol=tcp src-address-list=qos-users-src
add action=change-dscp chain=postrouting comment="Mark MEDIUM AF31(26)" dst-address-list=qos-medium-dst dst-port=7000-7999 log-prefix=MARKAF31 new-dscp=26 protocol=udp
add action=change-dscp chain=postrouting comment="Mark MEDIUM AF31(26)" dst-port=7000-7999 new-dscp=26 protocol=udp src-address-list=qos-medium-src
add action=change-dscp chain=postrouting comment="Mark LIVESTREAM EF(46)" dst-address-list=qos-livestream-dst dst-port=8000-8999 new-dscp=46 protocol=udp
add action=change-dscp chain=postrouting comment="Mark LIVESTREAM EF(46)" dst-port=8000-8999 new-dscp=46 protocol=udp src-address-list=qos-livestream-src
# set priority based on DSCP
add action=set-priority chain=postrouting comment="DSCP 0 CoS 0" dscp=0 new-priority=0
add action=set-priority chain=postrouting comment="DSCP 8 CoS 1" dscp=8 new-priority=1
add action=set-priority chain=postrouting comment="DSCP 16 CoS 2" dscp=16 new-priority=2
add action=set-priority chain=postrouting comment="DSCP 24 CoS 3" dscp=24 new-priority=3
add action=set-priority chain=postrouting comment="DSCP 26 CoS 3" dscp=26 log-prefix=DSCP26 new-priority=3
add action=set-priority chain=postrouting comment="DSCP 32 CoS 4" dscp=31 new-priority=3
add action=set-priority chain=postrouting comment="DSCP 40 CoS 5" dscp=40 new-priority=5
add action=set-priority chain=postrouting comment="DSCP 46 CoS 5" dscp=46 new-priority=5
add action=set-priority chain=postrouting comment="DSCP 48 CoS 6" dscp=48 log-prefix=DSCP48 new-priority=6
add action=set-priority chain=postrouting comment="DSCP 56 CoS 7" dscp=56 new-priority=7
# mark packets
# WAN
add action=accept chain=postrouting comment="UP IP Precedence (aka Packet Priority) 0 - Best Effort (Low Priority) (default)" out-interface=vlan3012 priority=0
add action=mark-packet chain=postrouting comment="UP IP Precedence (aka Packet Priority) 1 - Scavenger (Bottom Priority) (apply packet mark ip_precedence_1)" new-packet-mark=up_ip_precedence_1 out-interface=vlan3012 passthrough=no priority=1
add action=mark-packet chain=postrouting comment="UP IP Precedence (aka Packet Priority) 2 - Background (Very Low Priority) (apply packet mark ip_precedence_2)" new-packet-mark=up_ip_precedence_2 out-interface=vlan3012 passthrough=no priority=2
add action=mark-packet chain=postrouting comment="UP IP Precedence (aka Packet Priority) 3 - Critical Data or Call Signaling (Medium-Low Priority) (apply packet mark ip_precedence_3)" new-packet-mark=up_ip_precedence_3 out-interface=vlan3012 passthrough=no priority=3
add action=mark-packet chain=postrouting comment="UP IP Precedence (aka Packet Priority) 4 - Interactive Video (Medium Priority) (apply packet mark ip_precedence_4)" new-packet-mark=up_ip_precedence_4 out-interface=vlan3012 passthrough=no priority=4
add action=mark-packet chain=postrouting comment="UP IP Precedence (aka Packet Priority) 5 - Voice (Medium-High Priority) (apply packet mark ip_precedence_5)" log-prefix=UP5 new-packet-mark=up_ip_precedence_5 out-interface=vlan3012 passthrough=no priority=5
add action=mark-packet chain=postrouting comment="UP IP Precedence (aka Packet Priority) 6 - Internetwork Control (High Priority) (apply packet mark ip_precedence_6)" new-packet-mark=up_ip_precedence_6 out-interface=vlan3012 passthrough=no priority=6
add action=mark-packet chain=postrouting comment="UP IP Precedence (aka Packet Priority) 7 - Network Control (Top Priority) (apply packet mark ip_precedence_7)" new-packet-mark=up_ip_precedence_7 out-interface=vlan3012 passthrough=no priority=7
# streaming devices vlan
add action=accept chain=postrouting comment="DN IP Precedence (aka Packet Priority) 0 - Best Effort (Low Priority) (default)" out-interface=vlan171 priority=0
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 1 - Scavenger (Bottom Priority) (apply packet mark ip_precedence_1)" new-packet-mark=dn_ip_precedence_1 out-interface=vlan171 passthrough=no priority=1
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 2 - Background (Very Low Priority) (apply packet mark ip_precedence_2)" new-packet-mark=dn_ip_precedence_2 out-interface=vlan171 passthrough=no priority=2
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 3 - Critical Data or Call Signaling (Medium-Low Priority) (apply packet mark ip_precedence_3)" new-packet-mark=dn_ip_precedence_3 out-interface=vlan171 passthrough=no priority=3
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 4 - Interactive Video (Medium Priority) (apply packet mark ip_precedence_4)" new-packet-mark=dn_ip_precedence_4 out-interface=vlan171 passthrough=no priority=4
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 5 - Voice (Medium-High Priority) (apply packet mark ip_precedence_5)" log-prefix=DN5 new-packet-mark=dn_ip_precedence_5 out-interface=vlan171 passthrough=no priority=5
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 6 - Internetwork Control (High Priority) (apply packet mark ip_precedence_6)" new-packet-mark=dn_ip_precedence_6 out-interface=vlan171 passthrough=no priority=6
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 7 - Network Control (Top Priority) (apply packet mark ip_precedence_7)" new-packet-mark=dn_ip_precedence_7 out-interface=vlan171 passthrough=no priority=7
# users vlan
add action=accept chain=postrouting comment="DN IP Precedence (aka Packet Priority) 0 - Best Effort (Low Priority) (default)" out-interface=vlan170 priority=0
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 1 - Scavenger (Bottom Priority) (apply packet mark ip_precedence_1)" new-packet-mark=dn_ip_precedence_1 out-interface=vlan170 passthrough=no priority=1
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 2 - Background (Very Low Priority) (apply packet mark ip_precedence_2)" new-packet-mark=dn_ip_precedence_2 out-interface=vlan170 passthrough=no priority=2
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 3 - Critical Data or Call Signaling (Medium-Low Priority) (apply packet mark ip_precedence_3)" new-packet-mark=dn_ip_precedence_3 out-interface=vlan170 passthrough=no priority=3
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 4 - Interactive Video (Medium Priority) (apply packet mark ip_precedence_4)" new-packet-mark=dn_ip_precedence_4 out-interface=vlan170 passthrough=no priority=4
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 5 - Voice (Medium-High Priority) (apply packet mark ip_precedence_5)" log-prefix=DN5 new-packet-mark=dn_ip_precedence_5 out-interface=vlan170 passthrough=no priority=5
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 6 - Internetwork Control (High Priority) (apply packet mark ip_precedence_6)" new-packet-mark=dn_ip_precedence_6 out-interface=vlan170 passthrough=no priority=6
add action=mark-packet chain=postrouting comment="DN IP Precedence (aka Packet Priority) 7 - Network Control (Top Priority) (apply packet mark ip_precedence_7)" new-packet-mark=dn_ip_precedence_7 out-interface=vlan170 passthrough=no priority=7
