QoS for RB711
Can anyone recommend me a RouterOS version for RB711 with working WMM?
I’ve tested 4.10 to 4.16 and 5.0 up to rc5 without success so far. I’ve played also with NV2, but it is not an option since there is no stable release of 5.0 yet.
The configuration I’m using is simple bridge with some 802.1p CoS remarking. The traffic prioritization is not working whatsoever.
Thank you in advance.
I recommend you use 3.30 or 4.16 version.they work is fine.
The QoS for 4.16 does not work.
I am not sure if 3.30 supports 802.11n radio.
The QoS for 3.20 does not work same.It looks Like to uninstall XEN components.
I’m going to use this router, so i also need to know if it supports WMM?
Do i need special license to configure this routerboard as access point?
RouterOS level 4 or above
Found only wmm checkbox, i was hoping to find some advanced wmm configuration, time intervals and so on.
