Hi, i have the current setup:
LAN1: 192.168.6.0/24 Interface: ether2-Core
LAN2: 192.168.7.0/24 Interface: ether3-Family
LAN3: 192.168.5.0/24 Interface: ether4-Core-Cisco
WAN: ISP DHCP Interface: internet-ether10
My Internet Speed is:
Download: 6.1mbps
Upload: 1.5mbps
I followed the wiki documentation, but was unsuccessful
So, help:
I want to set my QoS tree like this: (QoS on Internet)
I want the LAN1 on ether2-Core to have high priority, unlimited speed. (Because my isp is always upgrading the speed without notification)
I want the LAN2 on ether3-Family to have normal priority, but i want them to have limited download: 2mbps, upload: 0.4mbps
I want the LAN3 to have the available bandwidth left.
Conditions:
- LAN1 must not slow down LAN2, so if LAN2 requires internet, LAN2 will have available 2mbps only.
- If LAN2 is not using the internet then LAN1 will have full bandwidth.
- LAN1 must not have any internet speed limitation (Because i am always monitoring the isp speed)
So please, help.
Thanks!
Hello!
Try this:
/queue simple add name=ISP target-addresses=0.0.0.0/0
/queue simple add name=LAN2 priority=6 target-addresses=192.168.7.0/24 max-limit=2M/400k limit-at=2M/400k parent=ISP
/queue simple add name=LAN1 priority=7 target-addresses=192.168.6.0/24 parent=ISP
/queue simple add name=LAN3 priority=8 target-addresses=192.168.5.0/24 parent=ISP
Hello!
Try this:
/queue simple add name=LAN2 priority=6 target-addresses=192.168.7.0/24 > max-limit=400k/2M limit-at=400k/2M > parent=ISP
#fixed the limits 400k/2M first upload then download.
@antkamidiv Thanks!, Karma +1
question:
if there are 3 clients in LAN2 (The one that have 2M) the connection fixes per ip? ex:
192.168.7.100 666K
192.168.7.101 666K
192.168.7.102 666K
or do i have to setup PCQ in Queue Type?, if so how?
The bandwidth isn’t divided into equal parts. You need create PCQ queues for incoming and outgoing traffic.
/queue type add name=“Download” kind=pcq limit=2M pcq-classifier=dst-address
/queue type add name=“Upload” kind=pcq limit=400k pcq-classifier=src-address
/queue simple set [ find name=“LAN2” ] queue=Upload/Download
