QoS make CPU Load 100% ?
Hi all,
i install MT for bridging Router and Qos. When Qos Running, CPU load Become 100% and packet icmp become higher about => 100 - 300 ms ( normal without Qos is =>2-4 ms )
i use :
IBM Server with Dual Xeon Processor 3200
RAM 2G
Hardisk 80 GB
2 Gigabit Ethernet
[admin@ROUTER1] > system resource print
uptime: 4h34m23s
version: “2.9.27”
free-memory: 837064kB
total-memory: 905760kB
cpu: “Intel(R)”
cpu-frequency: 3200MHz
cpu-load: 100
free-hdd-space: 76816700kB
total-hdd-space: 76904380kB
write-sect-since-reboot: 496904
write-sect-total: 17295064
How solve to this problem?
Anyone can help with my Problem?
Somethig is wrong
How much data you push?
I do 1TB per month on a small rb500 with qos and cpu 40-50%
push data about 200 User Online, when i inactive qos my MT Router Normal Again?..there is wrong with my Hardware or MT?
check your configuration for any flaws. maybe some where you cna do something a bit diferent. like queues not for each users but for user groups etc.
yes, inspect all config, maybe you have some bugs there. if possible, use PCQ, it will reduce the number of queues needed
Check your pps, looks like you have BIG pps… mine also like that.. 20 Mbit with 20000 pps, cpu resource is ~ 60-80%
CMIIW
