Good day,
I had read a lot of documentation on the official website: http://wiki.mikrotik.com/wiki/Manual:TOC and spend a lot of time in my findings but I still haven’t idea how to implement my idea in life.
I have attached the Network diagram and QoS algorithm how I wish to configure my router. Could you look on this please? And give me your advice if it’s possible to do or not. If not then I hope together we will find a workaround solution.
Please let me know if more information are reared.
Let’s simplify my requirements. At this moment I would like just to decrease traffic usage by torrent client when users are using Internet. According to the config bellow I can mark torrent’s packets in the Mangle rules correctly (see screenshot below). But when the torrent client is active there is no way to share the bandwidth for packets with the higher priority (another one screenshot but with different structure then in the ROS code). Could you advise please what should be improved?
/ip firewall mangle
add action=mark-connection chain=prerouting comment=DNS connection-state=new new-connection-mark=DNS port=53 protocol=udp
add action=mark-packet chain=prerouting connection-mark=DNS new-packet-mark=DNS passthrough=no
add action=mark-connection chain=postrouting connection-state=new new-connection-mark=DNS port=53 protocol=udp
add action=mark-packet chain=postrouting connection-mark=DNS new-packet-mark=DNS passthrough=no
add action=mark-connection chain=prerouting comment=ICMP connection-state=new new-connection-mark=ICMP protocol=icmp
add action=mark-packet chain=prerouting connection-mark=ICMP new-packet-mark=ICMP passthrough=no
add action=mark-connection chain=postrouting connection-state=new new-connection-mark=ICMP protocol=icmp
add action=mark-packet chain=postrouting connection-mark=ICMP new-packet-mark=ICMP passthrough=no
add action=mark-packet chain=postrouting comment=ACK new-packet-mark=ACK packet-size=0-123 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=prerouting new-packet-mark=ACK packet-size=0-123 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-connection chain=prerouting comment=UDP_TORRENT connection-state=new new-connection-mark=UDP_TORRENT port=6881-6891 protocol=udp
add action=mark-packet chain=prerouting connection-mark=UDP_TORRENT new-packet-mark=UDP_TORRENT passthrough=no
add action=mark-connection chain=prerouting comment=UDP connection-state=new new-connection-mark=UDP protocol=udp
add action=mark-packet chain=prerouting connection-mark=UDP new-packet-mark=UDP passthrough=no
add action=mark-connection chain=prerouting comment=E-MAIL connection-state=new new-connection-mark=E-MAIL port=110,995,143,993,25,465,587,2525 protocol=tcp
add action=mark-packet chain=prerouting connection-mark=E-MAIL new-packet-mark=E-MAIL passthrough=no
add action=mark-connection chain=prerouting comment=HTTP connection-mark=!HTTP_BIG connection-state=new new-connection-mark=HTTP port=80,443 protocol=tcp
add action=mark-connection chain=prerouting connection-bytes=500000-0 connection-mark=HTTP connection-rate=200k-100M new-connection-mark=HTTP_BIG protocol=tcp
add action=mark-packet chain=prerouting connection-mark=HTTP_BIG new-packet-mark=HTTP_BIG passthrough=no
add action=mark-packet chain=prerouting connection-mark=HTTP new-packet-mark=HTTP passthrough=no
add action=mark-connection chain=prerouting comment=TCP_TORRENT connection-state=new new-connection-mark=TCP_TORRENT port=6881-6891 protocol=tcp
add action=mark-packet chain=prerouting connection-mark=TCP_TORRENT new-packet-mark=TCP_TORRENT passthrough=no
add action=mark-connection chain=prerouting comment=OTHER connection-mark=no-mark new-connection-mark=OTHER
add action=mark-packet chain=prerouting connection-mark=OTHER new-packet-mark=OTHER passthrough=no
/queue tree
add max-limit=2800k name=LEVEL_A_UP parent=ether1 priority=7 queue=default
add max-limit=2800k name=LEVEL_A_DOWN parent=ether2 priority=7 queue=default
add max-limit=2800k name=LEVEL_B_UP parent=ether1 priority=7 queue=default
add max-limit=2800k name=LEVEL_B_DOWN parent=ether2 priority=7 queue=default
add max-limit=2800k name=LEVEL_C_UP parent=ether1 queue=default
add max-limit=2800k name=LEVEL_C_DOWN parent=ether2 queue=default
add name=ACK_U packet-mark=ACK parent=LEVEL_A_UP priority=1 queue=default
add name=ACK_D packet-mark=ACK parent=LEVEL_A_DOWN priority=1 queue=default
add name=DNS_U packet-mark=DNS parent=LEVEL_A_UP priority=2 queue=default
add name=DNS_D packet-mark=DNS parent=LEVEL_A_DOWN priority=2 queue=default
add name=ICMP_U packet-mark=ICMP parent=LEVEL_A_UP priority=3 queue=default
add name=ICMP_D packet-mark=ICMP parent=LEVEL_A_DOWN priority=3 queue=default
add name=UDP_U packet-mark=UDP parent=LEVEL_B_UP priority=1 queue=default
add name=UDP_D packet-mark=UDP parent=LEVEL_B_DOWN priority=1 queue=default
add name=OTHER_U packet-mark=OTHER parent=LEVEL_C_UP priority=1 queue=default
add name=OTHER_D packet-mark=OTHER parent=LEVEL_C_DOWN priority=1 queue=default
add name=HTTP_U packet-mark=HTTP parent=LEVEL_B_UP priority=3 queue=default
add name=HTTP_D packet-mark=HTTP parent=LEVEL_B_DOWN priority=3 queue=default
add name=HTTP_BIG_U packet-mark=HTTP_BIG parent=LEVEL_B_UP priority=3 queue=default
add name=HTTP_BIG_D packet-mark=HTTP_BIG parent=LEVEL_B_DOWN priority=3 queue=default
add name=E-MAIL_U packet-mark=E-MAIL parent=LEVEL_B_UP priority=2 queue=default
add name=E-MAIL_D packet-mark=E-MAIL parent=LEVEL_B_DOWN priority=2 queue=default
add name=TCP_TORRENT_U packet-mark=TCP_TORRENT parent=LEVEL_C_UP priority=2 queue=default
add name=TCP_TORRENT_D packet-mark=TCP_TORRENT parent=LEVEL_C_DOWN priority=2 queue=default
add name=UDP_TORRENT_U packet-mark=UDP_TORRENT parent=LEVEL_C_UP priority=2 queue=default
add name=UDP_TORRENT_D packet-mark=UDP_TORRENT parent=LEVEL_C_DOWN priority=2 queue=default
