My mikrotik works as pppoe server for clients and there are about 1200 clients connecting to internet on mikrotik. Sometimes internet connection can be really busy. On that times, my clients who play world of warcraft(wow) has packet loss or high ping. I want them to play with low ping and I research about wow and I found its using port 3724. I want to set piority to 3724 port and my question is how can I?? Thanks…
http://mum.mikrotik.com/presentations/CZ09/QoS_Megis.pdf video: http://www.tiktube.com/?video=247 (big - HD)
http://wiki.mikrotik.com/wiki/Connection_Rate
Find the address ranges owned by Blizzard Entertainment and prioritize all traffic comming and going to those addresses. Basic principles in post above.
I’ve found layer-7 regexp for wow. if I set piority 1 for that packets in firewall mangle, does it work? I am new at mikrotik and I know myself. I am a good learner with examples then explanations. Not starting with explanations. The language is also a problem for me because english is not my own language but it is not a huge problem also. Thank you guys.
actually, this priority is simply inserted into VLAN tagged packets or WMM wireless packets. to prioritize packets inside the router, you need to use queues
Try the following, i use masquerade, so that is why im using global_out as my downstream parent. Im not 100% positive it is set up correctly.. and sorry for no comments. Maybe someone can spot check the queues and mangle rules and confirm that priority will work… packets flow through fine, so i assume it works… but packets flow’d before their was parent queue as well… I believe its set up right with the priority set on the leafs now.
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0
max-limit=10M name=downstream_qos packet-mark=“” parent=global-out
priority=1 queue=default
max-limit=1M name=upstream_qos packet-mark=“” parent=wan1 priority=1
queue=default
max-limit=10M name=lan_qos_low packet-mark=“” parent=downstream_qos
priority=8 queue=default
max-limit=10M name=lan_qos_high packet-mark=“” parent=downstream_qos
max-limit=1M name=wan1_qos_high packet-mark=“” parent=upstream_qos
max-limit=700k name=wan1_qos_low packet-mark=“” parent=upstream_qos
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=5M
max-limit=10M name=lan_wow packet-mark=wow parent=lan_qos_high priority=1
queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=512k
max-limit=1M name=wan1_wow packet-mark=wow parent=wan1_qos_high priority=
1 queue=default
max-limit=10M name=lan_vent packet-mark=vent parent=lan_qos_high
priority=2 queue=default
max-limit=1M name=wan1_vent packet-mark=vent parent=wan1_qos_high
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=350k
max-limit=700k name=wan1_low_prior packet-mark=low_priority parent=
wan1_qos_low priority=8 queue=default
max-limit=9M name=lan_low_priority packet-mark=low_priority parent=
lan_qos_low priority=8 queue=default
/Ip firewall mangle
add action=mark-packet chain=postrouting comment=“” disabled=no dst-port=3724
new-packet-mark=wow passthrough=no protocol=tcp src-address=
192.168.1.0/24
add action=mark-packet chain=prerouting comment=“” disabled=no in-interface=
wan1 new-packet-mark=wow passthrough=no protocol=tcp src-port=3724
wan1 new-packet-mark=vent passthrough=no protocol=tcp src-port=5421
add action=mark-packet chain=postrouting comment=“” disabled=no dst-port=5421
add action=mark-packet chain=forward comment=“” disabled=no new-packet-mark=
low_priority passthrough=no
good luck!
