qos + pcc on different bandwith interfaces
Good day.
There are several posts on forum about qos + pcc but i didn’t find an answer.
My question is how to deal with qos on several interfaces (1 LAN and 2,3,… WAN). I am buiding first config.
  1. I think that i can’t use global-xxx virtual interfaces for queues because of different bandwith. So i would marking in mangle forward/postrouting and use queue for each WAN.
  2. There is another difficulty with queue on LAN that aggregates output from both WAN. I could set total of WAN ingress-bandwith for max-limit of LAN queue, but max-limit will be broken on WAN failure?
Did someone faced this problem? How do you run with several isp and qos especially when interfaces have different bandwith?
got an simple idea. I should divide parent queue that has max-limit = total of wan to child queues. This way i can max-limit them by corresponding interface bandwith. And even use global-xxx virtual interfaces with such childs. That’s right? Go for tests…
