QoS - queue limits on 802.11a ptp links
Hi, please help to use the right way …
I am using 5GHz simple links between APs and main router/shaper - connected to provider. It is mesh topology. QoS on the shaper works quite fine, but I have to go inside the network to build QoS also on internal links, because of our bandwidth to the provider is quite same as bandwidth of internal links (and provider BW will be higher in near future) and also because of internal traffic inside my network.
Currently I have a problem (may be only in my head …) that bandwidth of 802.11a link is not simple, because one direction is influenced by traffic in opposite direction (link with nominal rate 54Mbps means unidirectional speed up to 30Mbps, but max speed in both direction in the same time is around 1/2, ie 15Mbps). I do not know how to define limit-at and max-limit queue parameters in this case (queue placed in Interface_out)?
nobody knows? :frowning:
