QOS Verification with configs.
I am new to QOS and Mikrotik and would like for someone to verify that my configs are correct. I want to give VOIP traffic high priority, P2P traffic lowest priority. HTTP traffic Med-High priority, and all other traffic Medium priority.
These are my MANGLE Rules.
0 ;;; VOIP Traffic - RTP
chain=forward protocol=udp dst-port=5004 action=mark-connection
new-connection-mark=VOIP_Traffic passthrough=yes
1 ;;; VOIP Traffic - RTP
chain=forward protocol=udp dst-port=5005 action=mark-connection
2 ;;; VOIP Traffic - IAX2
chain=forward protocol=udp dst-port=4569 action=mark-connection
3 ;;; VOIP Traffic - IAX1
chain=forward protocol=udp dst-port=5036 action=mark-connection
4 ;;; VOIP Traffic - SIP
chain=forward protocol=udp dst-port=5060 action=mark-connection
5 ;;; VOIP Taffic - SIP
chain=forward protocol=udp dst-port=5061 action=mark-connection
6 ;;; VOIP Traffic
chain=forward connection-mark=VOIP_Traffic action=mark-packet
new-packet-mark=VOIP_Packet passthrough=yes
7 ;;; VOIP Traffic - Change TOS
chain=forward packet-mark=VOIP_Packet action=change-tos
new-tos=min-delay
8 ;;; HTTP Traffic
chain=forward protocol=tcp dst-port=80 action=mark-connection
new-connection-mark=HTTP_Traffic passthrough=yes
9 ;;; HTTPS Traffic
chain=forward protocol=tcp dst-port=443 action=mark-connection
10 ;;; HTTP Traffic - Packet Mark
chain=forward connection-mark=HTTP_Traffic action=mark-packet
new-packet-mark=HTTP_Packet passthrough=yes
11 ;;; P2P Traffic Connection
chain=forward p2p=all-p2p action=mark-connection
new-connection-mark=P2P_Connection passthrough=yes
12 ;;; P2P Traffic Packet
chain=forward connection-mark=P2P_Connection action=mark-packet
new-packet-mark=P2P_Packet passthrough=yes
13 ;;; Other Client Traffic
chain=forward action=mark-connection new-connection-mark=Other_Traffic
passthrough=yes
14 ;;; Other Client Traffic - Packet Mark
chain=forward connection-mark=Other_Traffic action=mark-packet
new-packet-mark=Other_Packet passthrough=yes
THESE ARE MY SIMPLE QUEUES
0 name="P2P_Traffic" dst-address=0.0.0.0/0 interface=all parent=none
packet-marks=P2P_Packet direction=both priority=8 queue=default/default
limit-at=320000/320000 max-limit=320000/320000 total-queue=default
total-limit-at=320000 total-max-limit=320000
1 name="VOIP_Traffic" dst-address=0.0.0.0/0 interface=all parent=none
packet-marks=VOIP_Packet direction=none priority=1
queue=fuze-default/fuze-default limit-at=0/0 max-limit=512000/512000
total-queue=fuze-default total-limit-at=1280000 total-max-limit=1280000
2 name="Web_Traffic" dst-address=0.0.0.0/0 interface=all parent=none
packet-marks=HTTP_Packet direction=none priority=2
queue=default-small/default-small limit-at=0/0 max-limit=0/0
3 name="Client_Other" dst-address=0.0.0.0/0 interface=all parent=none
packet-marks=Other_Packet direction=none priority=4
THESE ARE MY QUEUE TYPES
0 name="default" kind=pfifo pfifo-limit=50
1 name="ethernet-default" kind=pfifo pfifo-limit=50
2 name="wireless-default" kind=sfq sfq-perturb=5 sfq-allot=1514
3 name="synchronous-default" kind=red red-limit=60 red-min-threshold=10
red-max-threshold=50 red-burst=20 red-avg-packet=1000
4 name="hotspot-default" kind=sfq sfq-perturb=5 sfq-allot=1514
5 name="fuze-default" kind=pcq pcq-rate=0 pcq-limit=50
pcq-classifier=src-address pcq-total-limit=10000
6 name="default-small" kind=pfifo pfifo-limit=10
THESE ARE THE INTERFACE QUEUES. Ethernet2 is the Outside interface to the public internet. Ether5 is the Physical internal interface. Servers and Clients are VLAN interfaces which are associated with Ether5
INTERFACE QUEUE
0 ether2 fuze-default
1 ether3 ethernet-default
2 ether4 ethernet-default
3 ether5 ethernet-default
4 Servers default
5 Clients fuze-default
I think I need to add a rule to give DSCP EF traffic priority 1.
Try to use passthrough=no on the “mark-packet” rules, so the traffic will not be remarked another time.
  1. first mark all p2p connections then all the packets, and only then handle all other traffic.
How does this look? I wasn’t sure about removing passthrough on the VOIP Packet marking because the next after this changes the TOS on all VOIP Packets that are marked. If I remove passthrough on the Voip Packet mark will the change TOS rule still work even though it is after the Voip packet mark rule?
MANGLE RULES
0 ;;; P2P Traffic Connection
1 ;;; P2P Traffic Packet
new-packet-mark=P2P_Packet passthrough=no
2 ;;; VOIP Traffic - RTP
3 ;;; VOIP Traffic - RTP
4 ;;; VOIP Traffic - IAX2
5 ;;; VOIP Traffic - IAX1
6 ;;; VOIP Traffic - SIP
7 ;;; VOIP Taffic - SIP
8 ;;; VOIP Traffic
9 ;;; VOIP Traffic - Change TOS
new-tos=min-delay
10 ;;; HTTP Traffic
11 ;;; HTTPS Traffic
12 ;;; HTTP Traffic - Packet Mark
new-packet-mark=HTTP_Packet passthrough=no
passthrough=yes
new-packet-mark=Other_Packet passthrough=no
if you need to alter marked packets then sure - do no set passthrough=no
change TOS and then remove from mangle (set passthrough=no)
