Hi all
I’ve run into a bit of an issue, when setting up my new QoS setup.
Using the following pdf guide here, http://mum.mikrotik.com/presentations/CZ09/QoS_Megis.pdf, I’ve managed to setup a nice working QoS system on my test bed in the office. The issue I’m having when implementing it for real on our network is the shaper RB has clients routed to it via a large amount of IPIP Tunnels.
On the test bed I simply selected one of the ethernet interfaces as the Parent for my Total Down queue tree, but if I select the ethernet interface of the shaper it will only pickup the IP addresses from the IPIP tunnels and not the IPs of the actual clients themselves. These IPs only appear on the IPIP Tunnel interfaces.
Can anyone suggest something that will help me get this working correctly?
Thanks in advance.
