QOS with TOS
Does Mikrotik do “Hardware” prioritization of packets marked with different TOS values? (TCP Stack implementation?)
Does Mikrotik only inspect / match / modify TOS field on packets?
Does router automatically prioritize packets marked with TOS, or does marked packets need to go through queues to affect prioritization?
Mikrotik v2.9 works with TOS, V3 with DSCP.
You can add, modify or remove the DSCP field.
Max
http://mikrotikexpert.com
http://maxid.com.ar
