QoS with VPNs
okay, im a beginner when it comes to complex Qos : )
two interfaces, a T1 for internet and a bridge for lan/wlan internally.
If I have unknown number of L2TP/PPTP tunnels connecting from remote sites to the router to get to services on the inside, is my only choice to use global-in and global-out? I’m working with 1200k available on the T1 and want to make sure the outer PPP tunnel isn’t throttled (encryption gets out of sync and comes to a halt) but everything in the tunnels needs to be queued, and obviouslly know what its parent max is.
yes, global-in/out ruleZ =)
