Hi again!.
I’m trying to setup QoS in my office with proxy enabled.
This is my actual config (primitive; only for test):
NAT
0 ;;; Masquerade a la red local
chain=srcnat action=masquerade src-address=192.168.1.0/24
out-interface=wan
1 ;;; Proxy
chain=dstnat action=redirect to-ports=3128 protocol=tcp
src-address=192.168.1.0/24 in-interface=lan dst-port=80
2 chain=dstnat action=redirect protocol=tcp src-address=192.168.1.0/24
in-interface=lan dst-port=53
3 chain=dstnat action=redirect protocol=udp src-address=192.168.1.0/24
4 chain=dstnat action=redirect protocol=tcp src-address=192.168.1.0/24
in-interface=lan dst-port=123
5 chain=dstnat action=redirect protocol=udp src-address=192.168.1.0/24
MANGLE
0 chain=postrouting action=mark-packet new-packet-mark=dnsFlow
passthrough=no protocol=icmp
1 chain=postrouting action=mark-packet new-packet-mark=httpFlow
passthrough=no protocol=tcp port=80,3128
QUEUE TREE
0 name="downstream" parent=lan limit-at=0 priority=8 max-limit=8M
burst-limit=0 burst-threshold=0 burst-time=0s
1 name="upstream" parent=wan limit-at=0 priority=8 max-limit=700k
2 name="up interactivo" parent=upstream packet-mark=dnsFlow limit-at=100k
queue=default-small priority=1 max-limit=700k burst-limit=0
3 name="up web" parent=upstream packet-mark=httpFlow limit-at=600k
queue=default-small priority=3 max-limit=700k burst-limit=0
4 name="down interactivo" parent=downstream packet-mark=dnsFlow
limit-at=1024k queue=default-small priority=1 max-limit=8M burst-limit=0
5 name="down web" parent=downstream packet-mark=httpFlow limit-at=0
queue=default-small priority=8 max-limit=8M burst-limit=0
If proxy is disabled, then QoS will work ok. If proxy is enabled… aaagh!
See screenshots.
Ummm… what’s wrong ?
