I intend to apply the QoS roules on my mikrotik, give more priority voice packets than data packets.
Regarding your experiences, is mikrotik powerful in QoS? So, when I prioriterize voice packets does they pass through firstly?
Mikrotik ROuterOS is a comprehensive set of tools, and the software will do EXACTLY what you tell it to do with your traffic.
So, the short answer to your question is yes. The long answer is that it depends on what other things you are doing with your traffic. Realise that RouterOS is so much more than a traffic shaper or QOS tool.
So please consider carefully your plan before deploying.
Ok, if you want more help on this why dont you describe here what you are trying to achieve then together we build a config to help you. That way we both work together. two heads better than one right?
Firstly thanks all of you for your help.
God bless that was invented Forums, and this one is GREAT!
I want to implement Voip technology on my net for international calls. Normally this will be done through internet connection.
But I have a limited bandwidth (1.2 Mbps). This bandwidth will be used both for navigating and voice calls.
In this case I thing to implement QoS on my Mikrotik.
Please, can someone help me how to build EFECTIVE QoS on our system?
[All outgoing/incoming calls will have one ip source/destination (IP of SIP PBX, 192.168.12.61/32)]
