Hi all !
Is it possible to use this QSFP+ (https://edgeoptic.com/Pub_downloads/Datasheets/SWDM4-40G-QSFP-350.pdf) to connect 2 CRS 3xx via 2 MMF cores ?
thx
Hi all !
thx
It ought to work in any CRS3xx with Q+ (40G) or XQ (40/100G) ports. Whether it actually does, no idea, unless someone tries or MT chimes in about it.
THE CRS3xx have QSFP+
The point is with LR4 modules you need 4x SFP+ port to reach 40Gb, maybe with this Modul it work with just one QSFP+…
I know that this is theoreticaö.. does anywone try this setup ?
