QSFP28 has multiple interfaces
I’m configuring a QSFP28 on a CRS510, and the config is as follows:
set [ find default-name=qsfp28-1-1 ] fec-mode=fec91 l2mtu=9014 mtu=9000
set [ find default-name=qsfp28-1-2 ] fec-mode=fec91 l2mtu=9014 mtu=9000
set [ find default-name=qsfp28-1-3 ] fec-mode=fec91 l2mtu=9014 mtu=9000
set [ find default-name=qsfp28-1-4 ] fec-mode=fec91 l2mtu=9014 mtu=9000
If I disable any of those four interfaces, the link goes down.
Why are there four layer 2 interfaces defined? It should be one interface (qsfp28-1) with four lanes when you monitor the optical stats.
You should use the first one, and keep the rest enabled. More details here: https://help.mikrotik.com/docs/display/ROS/MikroTik+wired+interface+compatibility#MikroTikwiredinterfacecompatibility-QSFP+/QSFP28interfacesupportedlinkrates
Okay, thanks for the link.
