I have been using cloudflare’s DoH until now and wanted to switch to quad9 as it seems more privacy friendly DNS provider (until I eventually find time to research how to build my own with Unbound).
Wanted to check with the Mikrotik community if anyone implemented the quad9 DoH in their setups. Does it need another certificate, how to test whether it actually work and how to interpret the results from the test/query they offer.
Thanks for the replies and the time you took to write one. Appreciate it!
If you are looking to make your own DNS at home, check out this video. Gives a general overview of using PiHole and Unbound. Great place to get started.
Thanks! I need more time to build the server and research the whole thing first. I will put your recommendation on my Home Server YouTube playlist though
