Quee Process High
Hi Dear Friend I used Simple queue For limit 2G BW on 1072 Router Cpu is High
Now suggest to me limt BW By quee tree ( mikroitk suggest used Queee Tree mark Packet )
Now do this
chain=prerouting action=mark-packet new-packet-mark=Nakhl-IN passthrough=yes dst-address-list=nakhl-IPS in-interface=Internet-INPUT-VLAN log=no log-prefix=“”
And limit RX packet by
name=“Nakhl-IN” parent=global packet-mark=Nakhl-IN limit-at=0 queue=default-small priority=8 max-limit=2000M burst-limit=0 burst-threshold=0 burst-time=0s bucket-size=0.1
This Configuration True ???
How second Question How llimit TX Rate ???
Another Question Avg Rate in queue Tree Packet Avge Rate or BW avg rate???
Hey
Do you have another system to test these changes?
In this particular case I would take that “advise” with a HUGE grain of salt, or better yet: just ignore it…
Simple queues are processed by multiple cpu cores, which spreads the load. Do you see that? Try monitoring with /tool profile
On the other hand for a queue tree, linked to a particular interface, only 1 cpu will be used. Given your bandwidth of 2gb, i’m pretty sure that a single cpu will NOT be able to process that queue fast enough. You’ll introduce a bottleneck.
Verify these remarks in your situation, to be sure.
But high(er) load is the price to pay for queueing high bandwidth.
