Hi all,
I would like to test the iot gateway functionality for a poc. This includes query some opc ua tcp backend (simulator) and send logs to a mqtt endpoint. I installed the iot package and are able to send mqtt messages.
Unfortunately I do not find out how to connect to a opc ua tcp endpoint. I’m not really sure if this is possible or only bluetooth and modbus could be used as input.
Thanks for your help in advance,
Andreas
