I have router with Router OS 6.35, 2 x ISP, IPSec VPN connections.
Strange problem when I connect to SMTP server (TCP 25):
- When I connect through mobile internet (lmt.lv) - port 25, 2525 working OK.
- When I connect through home WiFi (also Mikrotik) - WORKING ONLY 2525 PORT! 25 not working, can’t connect.
- same thing like (2) when I connect from other wifi (TP-LINK)
- same thing like (2) when I connect from other mobile internet tele2.lt.
What is this?
add chain=forward src-address=193.203.196.0/24
add chain=forward src-address=193.111.247.0/24
add chain=forward comment="allow ping" protocol=icmp
add chain=input comment="allow VPN" in-interface=ISP1 protocol=ipsec-esp
add chain=input dst-port=500 in-interface=ISP1 protocol=udp
add chain=output out-interface=ISP1
add chain=output out-interface=ISP2
add chain=forward comment="established connections" connection-state=established
add chain=forward comment="related connections" connection-state=related
add chain=input comment="allow router access (www,winbox)" dst-port=81,8291 in-interface=ISP1 protocol=tcp
add chain=input dst-port=81,8291 in-interface=ISP2 protocol=tcp
add action=drop chain=forward comment="invalid connections" connection-state=invalid
add chain=srcnat comment=Kosmolat dst-address=192.168.1.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.1.0/24
add chain=srcnat dst-address=192.168.17.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.18.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.17.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.18.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.16.0/24
add chain=srcnat dst-address=192.168.2.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.13.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.13.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.2.0/24
add chain=srcnat dst-address=192.168.3.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.3.0/24
add chain=srcnat dst-address=192.168.20.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.20.0/24
add chain=srcnat dst-address=192.168.4.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.4.0/24
add chain=srcnat dst-address=192.168.6.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.6.0/24
add chain=srcnat dst-address=192.168.7.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.7.0/24
add chain=srcnat dst-address=192.168.8.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.8.0/24
add chain=srcnat dst-address=192.168.9.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.9.0/24
add chain=srcnat dst-address=192.168.16.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.10.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.10.0/24
add chain=srcnat dst-address=192.168.11.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.11.0/24
add chain=srcnat dst-address=192.168.12.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.12.0/24
add chain=srcnat dst-address=192.168.14.0/24 src-address=192.168.0.0/24
add chain=srcnat dst-address=192.168.0.0/24 src-address=192.168.14.0/24
add chain=srcnat dst-address=172.30.209.0/24 src-address=192.168.0.0/24
add action=masquerade chain=srcnat comment=Maskarad out-interface=ISP1
add action=masquerade chain=srcnat out-interface=ISP2
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=192.168.0.0/24 out-interface=bridge1 src-address=192.168.0.0/24
add action=dst-nat chain=dstnat comment="Mail server (SMTP, POP3)" dst-port=25,2525 in-interface=ISP2 protocol=tcp to-addresses=\
192.168.0.5 to-ports=25
add action=dst-nat chain=dstnat dst-port=25,2525 in-interface=ISP1 protocol=tcp to-addresses=192.168.0.5 to-ports=25
add action=dst-nat chain=dstnat dst-port=110 in-interface=ISP2 protocol=tcp to-addresses=192.168.0.5 to-ports=110
add action=dst-nat chain=dstnat dst-port=110 in-interface=ISP1 protocol=tcp to-addresses=192.168.0.5 to-ports=110
add action=dst-nat chain=dstnat comment=Webmail dst-address=ISP1_IP dst-port=8080 protocol=tcp to-addresses=192.168.0.5 to-ports=80
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=50000 in-interface=ISP1 protocol=tcp to-addresses=192.168.0.55 to-ports=\
50000
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=21 protocol=tcp to-addresses=192.168.0.200 to-ports=21
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=80 protocol=tcp to-addresses=192.168.0.149 to-ports=80
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=53 protocol=udp to-addresses=192.168.0.5 to-ports=53
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=1614 protocol=udp to-addresses=192.168.0.5 to-ports=1614
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=53 in-interface=ISP2 protocol=udp to-addresses=192.168.0.5 to-ports=53
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=53 in-interface=ISP2 protocol=tcp to-addresses=192.168.0.5 to-ports=53
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=1433 protocol=tcp to-addresses=192.168.0.157 to-ports=1433
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=50000 protocol=tcp to-addresses=192.168.0.55 to-ports=50000
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=1723 protocol=tcp to-addresses=192.168.0.200 to-ports=1723
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=1723 protocol=tcp to-addresses=192.168.0.200 to-ports=1723
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=5901 protocol=tcp to-addresses=192.168.0.200 to-ports=5901
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=2121 protocol=tcp to-addresses=192.168.0.200 to-ports=2121
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=2121 protocol=tcp to-addresses=192.168.0.200 to-ports=2121
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=5910 protocol=tcp to-addresses=192.168.0.108 to-ports=5910
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=5910 protocol=tcp to-addresses=192.168.0.108 to-ports=5910
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=5901 protocol=tcp to-addresses=192.168.0.200 to-ports=5901
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=2222 protocol=tcp to-addresses=192.168.0.5 to-ports=2223
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=2222 protocol=tcp to-addresses=192.168.0.5 to-ports=2223
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=21 protocol=tcp to-addresses=192.168.0.200 to-ports=21
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=10000-10002 protocol=tcp to-addresses=192.168.0.200 to-ports=10000-10002
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=10000-10002 protocol=tcp to-addresses=192.168.0.200 to-ports=10000-10002
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=3389 protocol=tcp to-addresses=192.168.0.200 to-ports=3389
add action=dst-nat chain=dstnat comment="RDP POSTTEST" dst-address=ISP2_IP dst-port=3395 protocol=tcp to-addresses=192.168.0.130 to-ports=\
3389
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=3390 protocol=tcp to-addresses=192.168.0.157 to-ports=3389
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=3391 protocol=tcp to-addresses=192.168.0.150 to-ports=3391
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=1610 protocol=udp to-addresses=192.168.0.150 to-ports=161
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=1615 protocol=udp to-addresses=192.168.0.159 to-ports=1615
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=1611 protocol=udp to-addresses=192.168.0.200 to-ports=1611
add action=dst-nat chain=dstnat dst-address=ISP1_IP dst-port=123 protocol=udp to-addresses=192.168.0.200 to-ports=123
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=53000 protocol=tcp to-addresses=192.168.0.157 to-ports=53000
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=143 protocol=tcp to-addresses=192.168.0.5 to-ports=143
add action=dst-nat chain=dstnat comment=Vsphere dst-address=ISP2_IP dst-port=443 protocol=tcp to-addresses=192.168.0.101 to-ports=443
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=1616 protocol=udp to-addresses=192.168.0.157 to-ports=161
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=3306 protocol=tcp to-addresses=192.168.0.149 to-ports=3306
add action=dst-nat chain=dstnat dst-address=ISP2_IP dst-port=2223 protocol=tcp to-addresses=192.168.0.149 to-ports=2223
