VLAN 10: Management VLAN (for managing network devices including the mikrotik’s)
VLAN 20: Client-VLAN (WiFi for laptops of internal users)
VLAN 30: Guest-VLAN (WiFi for guests)
the names of the vlan are created for test purpose
The dhcp server is a router based on PfSense which has these 3 VLAN’s attached.
On the dhcp server i see the reqeust for a ip and also see the reply for that request.
But the client ( have tested it on Client en Guest WiFi ) wont get a respons.
When the client sets a static ip for WiFi i can’t even ping the router.
You should add the VLAN interface on the bridge interface and not on the ether5 interface as the ether5 interface is a part of the bridge ports. Set all the vlans to the BR-WiFi interface.
