Question About CCR1036
Hi , i have a Router OS in a Quad Core Xeon Server with 4 GB Ram , but i have problem with queues , i need several queues , like :
/queue simple add dst-address=110.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=111.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=112.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=113.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=114.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=115.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=116.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=117.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=118.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=119.0.0.0/8 max-limit=256000/256000
/queue simple add dst-address=120.0.0.0/8 max-limit=256000/256000
The server that i m using is rebooting when many CPU are used .
So i need to know if the CCR1036 will work fine with the Queues .
What i need to do , is limited Bandwith used in Countrys like China or Japan .
Is for a Data Center that trafic permanently 50000 Packets per Second , and 500 MB per second .
What is the best solution ?
Thank You Very Much
