Hi
I was trying to find a route in my route table (15K) and found this and was puzzled by it
doing this
/ip route print detail where 203.82.140.125 in dst-address
found me this
49 ADb dst-address=203.82.128.0/19 gateway=175.45.107.73 gateway-status=175.45.107.73 reachable via YBPublicVocus distance=20 scope=40 target-scope=10
bgp-as-path=“4826,2497,7991,3561” bgp-origin=igp bgp-communities=4826:5902,4826:6560 received-from=alcvocus
which is what I wanted
I am wondering why when I do this
/ip route print detail where dst-address=203.82.140.125
can I presume the first one is using network logic to say what route matches and the second one is doing some sort of string search.
so why doesn’t this work
or
/ip route print detail where dst-address~203.82
and where do I find more info on the “in” command used on the first example !!!
one last bit to is how do i simulate a ip route get ? from linux ask the routing table how it would route !
