Good day,
I would like to know, why sometimes when I create an Ipsec tunnel it creates two or more tunnels with the same ips, sometimes after few seconds sometimes after few hours.
For example in this case it create first the 1-3 tunnel, then the 2-4, (and the 2 with both algorithm none ???)
The tunnel “works”, when I do ping the 2-4 are the ones up.
When I make more than one tunnel, it gets a bit chaotic.
Someone had the same problem? Or knows why it could happen?
Also, I have the problem that after x hours the tunnel breaks and the only solution I have is to kill connections. Now is ok because I have only one, but in the case I have 2 or 3 i would have to kill all the connections to make one work, anyone knows why?
In this case the connection is between Mikrotik 6.24 and Fritzbox.
Any help would be appreciated, thank you
