Hello everyone,
The IRQ adaptive setting is OFF by default for Intel NICs, while it is ON by default for Mellanox NICs.
During L3 forwarding under a load of 500 Mbps and 100k pps, the CPU usage shows a fourfold difference between the two NICs.
Is it possible for RouterOS to enable adaptive-rx?
Is it feasible to manually configure rx-usecs or rx-frames?
If it’s not currently supported, is there any plan to allow such modifications in the future?
