Question About LHG LTE Kit
Hello, i’m and happy owner of the LHG LTE router but i have a big question.
The router is equipped witha Category 4 modem for speeds of up to 150 Mbit/s but have one Ethernet port 10/100.
The question is, if the lte modem can get 150 Mbit/s how can i use them if ethernet port is 100 Mbit/s?
Thanks a lot for all your response
Regards
Stefano
Simply you can’t. You are limited at 100 MBit/s… This is not a problem, a 150Mbit/s (cat 4) modem hardly reach 100 Mbit/s in real life.
Thanks a lot for you response!! :slight_smile:
