Hello. I have question about some mysterious for me lines in mikrotik log.
16:47:01 store,debug adding system drive: primary-master (/dev/hda)
16:47:01 store,debug user-manager1: disk setup finished successfully
16:47:01 store,debug web-proxy1: disk setup finished successfull
I have a lot of these lines,
I`m wondering if it may cause problems, and in consequence force my alix2d2
to reboot after 7-10 days running. It happens so, that why im trying to determine the cause.
(1532 messages not shown)
oct/03/2011 23:39:33 store,debug adding system drive: usb1 (/dev/sda)
oct/03/2011 23:40:04 store,debug adding system drive: usb1 (/dev/sda)
oct/03/2011 23:40:34 store,debug adding system drive: usb1 (/dev/sda)
oct/03/2011 23:41:04 store,debug adding system drive: usb1 (/dev/sda)
oct/03/2011 23:41:34 store,debug adding system drive: usb1 (/dev/sda)
oct/03/2011 23:42:04 store,debug adding system drive: usb1 (/dev/sda)
oct/03/2011 23:42:34 store,debug adding system drive: usb1 (/dev/sda)
oct/03/2011 23:43:04 store,debug adding system drive: usb1 (/dev/sda)
Seems the user database is lost (until reboot) and nothing can be written. I think the usb disk is ejected somehow. Anyone else have these issues on x86 using usb for flash disk? I will move to sata since usb bus is unreliable, just interesting to see this happen on multiple supermicro atom boards using industrial usb flash for the install.
I saw this too
when i activated the debugging and Starting PPPOE Server/Client it debugs, but when disabled them the debugs won’t stop! what was it debug?
im talking about another thing, not debug options, but what i see in debug, im looking for a reason to make mi MK hang for a minute or two, and i think its USB related
however for some reason i decided to reset the MK and start again using winbox from linux, i did all the same setup and seems to be working i have yet to try the other microsd and usb drive, however i also had weird problems before using any storage device
