question about mikrotik ccr 1072 power supply
I have a ccr 1072 and psu1 and psu2 has voltage (one of them is 12v and other one is 12.1v) but psu1 current is 0.0 A amps and psu2 is 6.1amps, so are both power supply healthy? and why does psu 1 is 0.00 ?Thank you.
Because it always choses to get power from the PSU with higher voltage: so one is currently used, and another is chosen as a backup.
ok got it,
so if it has 0 voltage then psu status is failed right?
bceayse ccr 1072 does not have psu status
On CCR1009 I own the behaviour is a bit different: it shows statuses (ok/failed) for both PSUs, but only the board voltage, not specifying which PSU is actually in use.
I guess you are right, on CCR1072 zero voltage should mean failed/unplugged.
Test it yourself: unplug psu2, the unit should switch to psu1.
And look what will it show for unplugged one.
