hi,
is there any possibilities to use modbus over rs-232?
we are using solar panels and observe battery states using modbus with snmp.
regards.
hi,
regards.
Here’s a wiki to enable use of the serial ports -
http://wiki.mikrotik.com/wiki/Serial_Port_Usage
You can then map the serial port to your PC to enable modbus integration.
