Hi, I installed Apache web server in a PC and I would like to open the port 80 on the Mikrotik 450G. I have connected the computer to a switch that is connected to ether2 ( LAN ). I tried already to many different ways but I can’t get it to work. http is working good in the LAN, but is not working with my real IP. Can somebody help me ? thanks for support.
You may need a NAT rule to map from the external IP and www or https port to the server.
BTW - Information about the current router config would help you get a better answer. There’s a standard list of exports that the pros ask for.
Thanks for the help, I just found a post with the same problem. Now, I understand how is working. thank you for support.
