I’m with the following problem when trying to enable MPLS in just 4 Mkts a total of 15. Strangely I can not navigate (browser) I can ping them all over and 8.8.8.8.
I put none of these Mkts that are not active MPLS access. Does it have something to do with OSPF?
Did you adjust the MTU values? Having the wrongs MTUs will cause the problem you are describing. Try pinging from one router to the next. Start with a Packet Size of 1500 and then work your way down until it starts pinging. If it won’t ping at 1500, that’s a dead giveaway.
