In a few days I’m going to receive a “gift”, an AP Ubiquiti AC Pro. I’ve seen in the datasheet that it supports PoE passive 48v, 9W and 0.5A.
Is it possible to use the PoE:out of a hAP ax² to power the AP?
Best regards!! ![]()
Albert.
Albert.
No. The hAPax2 “dual use” PoE port is passive, but it does support 48V input.
Hello Amm0,
Thank you very much for your response, in that case I will buy a PoE injector.
