Question about PPPoE ans Mark-Route
Hello
I’m trying to implement a new work, where the clients will connect to the server ussing PPPoE connections and then deppending in the service (http, ftp, mail, etc) will have different routes.
I configurated the PPPoE Server without any problem!
My problem appears, when I need to route the traffic between two WAN. I’ve to mark some type of traffic, like http, vpn, and chat and send its to the WAN1, and the other traffic to WAN2.
Well, I tried making the mangle in prerouting or in output and nothing :frowning: First of all I mark the connections and the with its I make a new mark-routing where I said WAN1 or WAN2, deppending in the route that they will have. Then in ip route I generated each route with his mark-routing (WAN1 or WAN2). And I think that it have to work, but NOT!! :frowning:
I changed the place where I generate the new mark-routing from prerouting to output, and vice versa, without any good result.
The only way that I can use internet is to generate a new ip route without any mark-routing. And it isn’t my solution because the traffic that have to travel in a special route, use the default route!!
Well thank I hope that someone can help me
Rafael Lore
