Question About RB433
Dear All,
I have an Office with ~30 Computers,
Can i connect them all into RB433 via Hotspot system to limit their down/up speed.
My Question is can the RouterBoard 433 handle the 30 active users on Hotspot with no problems
My input connection speed is ~ 1mbps
Thanks so much
I don’t use hotspot or a 1meg connection, but the simple answer is yes it will. I use a RB433AH with about 200 wireless clients connected to and span a large wireless setup for many users.
I suggest if your totally new to MT though getting used to the manual / forum (which you’ve done) and perhaps even buying a book.
Josh
