Question about RB433AH & Xagyl FLR24G30 mini pci
Hello all,
Ive ordered for 2 cards Xagyl FLR24G30 ( 2.3 GHZ ~ 2.7 GHZ B/G ) 1000mW internally limited up to 1333 mW
I have tested the card on Rb433Ah but I’ve found before i put it online that this card only shows the TC POWER RATES as 17dBm im confused why its showing like that but the card is 31dBm
Can anyone explain to me or if anyone tried this card before .. I appreciate your help
I also want to mention that when i replace it with Mikrotik R52H Card then the TX POWER shows as 25dBm !!!
Do you mean that this card isnbt compatible with Mikrotik to produce full power ?
Thank you
that card has a really great offset tx power :neutral_face:
Hello are you sure it has a great power but why im seeing its tx power as 17dBm? or i should not worry about its power or the Mikrotik software decreases its tc power to 17 dBm thats why im really confused about it ,
my first time i use this kind mini pci
from tx 17 to 30 it has some amplifier in the card.. so .. leave it in default tx power and Njoy!!!
Thank you guys for your information I will re-install it again and test it :smiley:
