Question about SC , APC UPC connectors
Hello I have a question.
At the moment we run a FTTH P2P infrastructure UPC connector’s based.
We use WDM UPC SFP and a mikrotik media converter on the other side.
All our distribution shelfs are 48x UPC (blue).
Question:
We are going to implement GPON and our consultants suggested to use APC (green) because of the better performances of the angled connectors.
I have a question now:
If I would like to run a part of the network in APC, I need to use everything APC, green,OK.
What about SFP? The SFP are UPC or APC? Do I need to use pigtails?
For example the MT SFP GPON, is PC, so I assume UPC. What if the whole infrastructure has APC connectors? Just use pigtails I assume
Either a APC to UPC patch lead, or as you say, most commonly they just splice the required pigtail on to the fiber yes with the appropriate mid-coupler.
Personally, I don’t buy into the whole APC thing being better…
Hello. thank you for your ansewer but you didnot answer to my question :smiley:
The standard SFP has PC connectors, so I assume UPC (blue). I should need a patchrod UPC → APC right?
The standard SFPs are UPC?
On the SFP it doesn’t matter - as long as it is the correct connector. You don’t get a APC and/or UPC SFP module.
It’s difficult to explain, but on a mid coupler, the plastic extending from the fiber connectors needs to be aligned correctly (either square (UPC) or angled (APC)). In a SPF module, the plastic extending from the fiber connector goes inside the receiver of the SFP (there’s a little slot that it slides into). So angled or not, it’s always a proper and correct fit.
Thank you.
But I remain with a big question.
All the SFP with SC connector, are UPC, blue ?
I know the mid coupler, no problem for that.
Yes all SFP with LC connectors are PC.
This means you need PC or UPC patch leads.
You can use APC to UPC patch leads to connect SFP to your APC patching.
APC is recommended for RF over fibre, e.g. GPON networks as it has lower reflection than PC/UPC connectors.
APC is also required if you are using optical circulators.
Yeah, SFP modules with LC connectors are PC. And UPC are more common used than APC.
Hope this article will be helpful.http://www.cables-solutions.com/whats-the-difference-between-upc-and-apc-connectors.html
