Question about the new Chateau Pro ax
Chateau Pro ax is an upcoming device but can anyone confirm that it will be 4MIMO - AX6000, core based model, amount of ram etc?
Here’s what we can decipher from the model name:
Chateau Pro ax - H53UiG-5HaxQ2HaxQ-US
  • H - Series
  • 5 - Wired interface count
  • 3 - 3 Wireless interfaces
  • U - USB
  • i - Single port power injector without a controller
  • G - Gigabit
  • 5 - 5Ghz
  • H - “High” - 23-24dBm at 6Mbps 802.11a; 24-27dBm at 6Mbps 802.11g
  • ax - WiFi proto
  • Q - Quad chain
  • 2 - 2Ghz
  • ax - WiFi proto
  • Q - Quad chain
Source: https://help.mikrotik.com/docs/display/ROS/Product+Naming
Thanks for the reply, but I have come to these conclusions as well, however the following things are puzzling me - if there is a 3 radios, which one is the third one? Two 5ghz radios with 2MIMO=4MIMO , or two with 4MIMO, or 2 radios with empty slot for third radio … with 80mhz channel or 160mhz channel support ?..
Hi, does Chateau Pro ax support LLDP and 802.3ad(dynamic bonding)?
