Is there ANY WAY that IP addresses in the torch view can be converted to hostnames? I am trying to debug access to some web sites and it would be so helpful to view the torch output as hostnames.
Thank you any help you can provide.
Rizwan
Rizwan
Hi again, Rizwan,
Not to my knowledge; however, instead of using Torch, you can use Packet Sniffer. It can work in a similar way but can stream the packet capture to an external IP where you have wireshark running. Then in wireshark you can probably show the hostnames somehow.
