Hello all,
first of all i want to say thanks to all for helping me. Now i want to inquire one thing from you. I want to use 3 or 4 VOIP Phones with my Mikrotik i am using Mikrotik Router OS v3.30.
Can we use VOIP Phones with mikrotik?
If yes then tell us how or send us link of wiki or any tutorial.
Thanks,
waiting for answer.
What exactly do you mean by using VoIP phones?
What would be your platform? Soft Switch, PBX? or u are planning on creating a PBX over Mikrotik with virtualization?
Regards,
We are running an 8 line talkswitch PBX with little setup. Just the port forwarding and QOS (optional). Mikrotik will work like any other router as far as voip goes.
Sure if that is the case, it will have no problem
hello,
thanks for answers. i don’t have any system now but i want to create a system so can you please tell me i can do this with wireless signals. if yes then how. any direction for search.
