Question about VPN, pools and subnets
I have an OpenVPN Server with the following settings:
/interface ovpn-server server
set auth=sha1 certificate=OpenVPN-Server cipher=aes256 default-profile=OpenVPN enabled=yes mode=ethernet require-client-certificate=yes
/ppp profile
add bridge=bridge local-address=192.168.87.1 name=OpenVPN remote-address=OpenVPN-Pool use-encryption=required
add name=OpenVPN-Pool ranges=192.168.87.2-192.168.87.254
How do I achieve that the devices connected to the VPN can communicate with my default local network that is using the following pool?
add name=Default-Pool ranges=192.168.88.2-192.168.88.254
I used two pools with two DHCP servers before and they could communicate by default, so I had to drop connections with a firewall rule, but here I can’t get the devices from the 192.168.87.0/24 to communicate with the devices from the 192.168.88.0/24 subnet.
Check your firewall settings. Probably the packets are getting dropped somewhere.
Do you see anything out of the ordinary, because I don’t?
add action=accept chain=input comment=OpenVPN dst-port=1194 protocol=tcp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=WAN
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
It depends on what is in LAN and WAN interface lists…
You also made some changes (like changing !LAN into WAN) that could have effect.
You also need to check if the routing table is OK on your client devices (is there a route that sends 192.168.88.0/24 traffic to the VPN).
I have reset my router to factory defaults. Same issues. Devices can’t talk to eachother.
Aren’t traffic, which is coming from the VPN clients, picked by these rules? Technically, connections are coming from WAN interfaces.
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=WAN
/ip firewall filter add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
Not sure about OpenVPN, but for IPSEC one must exclude such traffic from fasttrack in order to avoid issues. Same applies to main NAT rule.
First thing to try would be to add simple filter that allows from to networks and vice versa above all other rules.
EDIT: Mmm yes, “drop all not coming from LAN”.
Yes in the default setup you would usually want to add the VPN interface to the LAN interface list.
With limited info available, it seems you are confusing VPN server between “Routed” and “Bridged”
As a start, for routed, remove below and test:
/ppp profile
I have disabled all of the rules and I devices still can’t communicate. Anyway, like I said, if I use the default pool in the VPN profile, everything works fine, so it can’t be a WAN > LAN issue.
If I remove bridge=bridge from the profile, I lose communication between devices even while using the same pool (local devices and devices connected through the VPN).
Let us see the whole config, provide results of /export file=filenameofyourchoice hide-sensitive
There you go mate.
Export.rsc (5.48 KB)
Also see
http://forum.mikrotik.com/t/vpn-with-tun-interface/145422/10
