Question before purchasing RouterOS
Question 1 : Can I upgrade from l4 to l5 or l6?
do I have to pay for the full amount or partial adjusted for l6?
Question 2 : If I purchases it .. can Mikrotik give me by doing its configuration?
Question 3: Does RouterOS supports onboard LAN if i go for servers like Dell power-edge or something like them?
Question 4:Can RouterOS supports the following system? how many users & how much bandwidth it can handle? approx?
Two Processor Xeon X5670
(2.93Ghz 6core 12thread x2no)
32 GB DDR3 memory
240 GB SSD HDD
460 w power
2 GiG LAN Cards
  1. No, MikroTik doesn’t support upgrades from one level to another. You can get higher license on device, but you have to pay full price. I don’t like that, but it’s their decision.
  2. If you mean that they would configure router for you, the answer is no. If you can’t do it yourself, you need to find someone else.
3,4) RouterOS is known to not support everything. If you want to be sure, download CD image and try to install it. It will run without any limits for 24 hours. Or there’s free L1 license, it works forever, but has some stuff limited.
Thank you very much, sir.
Just test CHR https://wiki.mikrotik.com/wiki/Manual:CHR
