Hi.
What can be done via the API to confirm yes/no question? Typically, for example…
/system reboot
Reboot, yes? [y/N]:
or
/system routerboard upgrade
Do you really want to upgrade firmware? [y/n]
… Is this possible?
Thanks for answer.
Hi.
/system reboot
Reboot, yes? [y/N]:
or
… Is this possible?
Thanks for answer.
no, that is not possible.
And for your given examples - commands are executed without confirmation as that is done in interactive environments.
If somewhere you see this - please report back so we can fix that.
