Hi, how can I forward a port?
you need to use DST-NAT
http://www.mikrotik.com/testdocs/ros/2.9/ip/nat_content.php#6.36.3.3
In the past I always do that by using Winbox but now its giving error.
in firewall I add nat rule
chain is dstnat
dstaddress is wan address
than action
action is dst-nat
to addresses is lan address
to ports is the port that I want to forward
but now it says: Couldn’t add new nat rule -
to-ports valid only for tcp/udp (6)
you have to select protocol TCP also
