Question for setting
Hi to all.
I have 3 mikrotik apparate for transport internet from point A to B and C.
A is qrt 5 ac
B is Mant15
C is qrt 5 ac
Distance A to B is 3km
Distance B to C is 6km
On B site signal is very good -55/-55 snr 45 tx rate 550 rx rate 550
Protocol used for link is nstreme.Nv or 802 is terrible!!! Set on AC 80Mhz end frequency 5450.No channel interference.
A is set station bridge and have modem connect for internet fiber 1000*100
B is set ap bridge
C is set station bridge and receive internet but i have only 50/55mb. On B site have 60/65mb.
My setting not is good? Have idea?
Any idea for my problem?
hello,
DO have find solution about you’r pb i need somes advices in the same case
No, I didn’t find any solution.
More than 50 / 60mb out of 1000 available does not go!
I’ve been experimenting with everything for months, but it’s all in vain!
Are you actually connecting both qrts to same sector of mant … making mant act as PtMP? I guess you’re suffering of the “hidden station” problem where stations A and C don’t hear each other (if they did, you wouldn’t need station B) and thus can’t avoid collisions. Bringing whole channel performance down due to many retransmissions.
I’d say you should use two PtP links … depending on the geometry (azimuths from station B towards stations A and C) you could build both PtP links using same frequency channel if used antennae would minimize interference.
