Hi
CCR1009-7G - OS 7
Anyone know the maximum # if interfaces bonding support on this CCR box? Also are all interfaces on the CCR1009-7G available for bonding?
Or can anyone point me to the Mikrotik documentation that provides this detail.
Already reviewed the on-line docs and examples - nothing there.
Bill
Since all ports are indivudal interfaces, and not switched ports, i think that all of them can be bonded.
Note that bonding is a in-software feature that will use CPU.
Do you need to bound all interface? What do you try to achieve?
I guess I can assume using the cpu for interface bonding would probably overload the box with a lot of traffic? Not sure.
I am attempting to setup redundancy.
Thank you
Bill
Then two interface bound together should be enough. ![]()
