Hello again savers ,
one of my MTs , its backup size is 3626.6 KiB ! isn’t huge ?
While other with similar configuration are normal backup size like 232.3 KiB
What cause this increment of the .backup size ?
maybe you have a lot of logs, big number of rules, or some custom hotspot folders?
Hello - I have the same issue. I have two RB1000’s both running RouterOS 3.24. Each is just set up with some VLANs, IP addresses and a few routes, with one having somewhat more entries than the other. The unit with the fewer entries has a backup file size of about 15KB, the one with somewhat more entries has a backup file size of 550KB! it does not have 30x the number of entries of the other unit, so something else is going on here. Any ideas? Should I be concerned?
Thanks!
550 Kb is quite small, so don’t worry
Hello - thanks. I am not particularly worried, just trying to understand why this backup file is so much larger than the other one. I’ve checked the configs for all the various router features, and I don’t see any other services being used that could account for the additional size. There must be some explanation…
- Ed
logs? hotspot? some files stored? branding?
I am a winner !!!
[admin@shaper-MIR] /file> print
# NAME TYPE SIZE CREATION-TIME
0 MikroTik-17032.backup file 61845989 apr/09/2009 16:28:01
1 Mir-MikroTik-2. backup 1025083 apr/09/2009 16:29:35
2 routeros-x86-3. package 16630188 may/22/2009 18:56:34
3 MikroTik-29052. backup 1443659 may/29/2009 00:54:01
58.9 MIB size of backup file, but i have 5347 simple queue )
you are crazy =)
why not use PCQ and have only a few rules, with the same result, and 10x better performance of router?
I don’t have a any custom logs set, just the default logs in the dist, they appear to only be about 100 lines each according to the config. No hotpsots created. No files stored on the file area. No branding. The size of the backup file is now 680KB, up about 130KB since my original post and I’ve only added two VLANs and two Routes. I guess it’s not a big deal if it is not an indication of some trouble, but I would like the file to be more compact. BTW, all I want to backup is the full router config, not any transient data like logs, arp tables, etc. Is there a way to specify this with the backup command? The docs don’t seem to indicate any available flags beyond ‘name’.
Thanks!
Ed
/export ?..
becose after 1-2 days API and ssh hangs (1-5 connection in 2-3 seconds, ver2.9 works fine, play with multicore dont help, on any V3 version)
Beacose of this i must use simple queue and API connection 1-2 in 10 minutes, and nothing hangs
No sir. And those would show up under /file anyway. As I said before, nothing in /file except a 6k auto-before-reset.backup that’s been there since the beginning. Any other ideas? Too bad the backup file is binary, otherwise we could just peek inside and see the whole system config. All my L2 switches use a plain text file for the config, I wonder why Mikrotik felt it necessary to go binary?
/export is plain config! /export file=mycfg
That’s true. When I export the whole system I get a file of about 33K in size, and nothing inside that would not be expected. What I am wondering, and what this thread is all about, is why the backup file is so much larger, assuming that it contains essentially the same data - and the backup file on my second router is just a tiny fraction of that size.
Still no explanation of the big file size discrepancy? Seems very odd…
Bizarro update to my original post. I had a client move off the router. Deleted his VLAN and his /27 - backup file size immediately dropped from 800k (it had grown since my original post) to 36k. I backup each time a I make a change, so removing this one client’s VLAN and IP subnet was the only visible change that can be attributed to the file size change. What gives with that?
Graphing?..
I did turn off graphing several days ago in a effort to try to reduce the backup file size, but it did not help with several backups since then the file size only went down after that minor change. I suppose it would be easy enough to test though, when I have some time…
I am seeing the same issue.
I run a script each night that exports and emails the backup on all my routers. on all of them this has grown to 4 megs over time.
Even on a single Point to Point link with NO special rules or settings, the file will start small after initial configuration and then over time keep growing. biggest i have currently is about 5Megs
But if you do an export the file size is only a few K
The backups still work but just take longer to export and clog up my email faster since they are now so large.
Does anyone have any real idea what is filling up this file?
I would be happy to send one of my backup files to someone for analysis if they would like to look for themselves.
There is not much in a point to point link backup file to even save…
